I need a bit of advice about the detail required between an existing pitched roof and dormer cheeks,
WBP ply has been fixed to the dormer cheeks and I'm ready to install the membrane prior to battening and tiling. This is where I need a bit of advice,
1. Should a cant rail be installed at the junction of the dormer cheeks meeting the existing roof? The membrane would then overlap the cant rail and finish at the existing roof, correct?
2. If the above is correct, how would soakers be installed as the cant rail would mean that the soakers cannot be 'L' shaped? Would this not also mean that the soakers would be visible as the cant rail would prevent the dormer cheek tiles and the pitched roof tiles from being installed close together?
If anyone has a diagram on how to detail this, that would probably answer all of my questions .
