Hi all,
I'm refitting a bungalow and have rebuilt the partitions using 100mm breeze blocks.
I wanted to have the whole lot plastered using bonding followed by a setting coat but I can't find a plasterer capable of/willing to do this. Every time I speak to a plasterer they tell me they only do dot and dab and then skim over the plasterboards, so I am now preparing the walls/partitions for dot and dab dry lining.
I've watched a few videos on this and it appears that the electrical knock-out boxes (25mm deep) are screwed directly to the face of the blocks, so that if the plasterboard finishes flush with the electrical boxes, there'a a 12 or 13mm void between the back of the plasterboard and the face of the blockwork. Is this correct?
Assuming I've got this right, I now need to fit the door linings to finish flush with the face of the plaster skim coat.
So, if I have 100mm blockwork and 25mm of plasterboard plus void on each side of the blockwork and allow 3mm for the skim coat, I reckon the door linings need to be 156mm (100mm for blocks, 2 x 25mm for dot and dab on each face then 2 x 3mm of plaster on each face) thick. Have I got this right?
Would love to hear from any dot and dab gurus out there.
Regards
Jever
Regards
Jever
