Dot and dab in long lines imitating joists spaced at regular intervals. When it's dry put a few screws through the board, through the dab and into the wall.
A definate no no; you can’t rely on just adhesive, the bond will only as strong as the foil to the back of the board. I’ve used the “through fixing” method after the adhesive has gone off on both Duplex & cement based tile backer boards but I use frame fixings rather than nailable plugs which can disturb the adhesive. You must make sure you fix through the adhesive dabs into the wall & not through fresh air.
You don’t need to go too mad with the adhesive; in this case all it’s doing is holding the boards in place on the wall until you make the mechanical fixing, it’s the screws that will be supporting the boards.
Apply the adhesive in strips, as joe 90 suggests & space the screws at least every 300mm, both horisontally & vertically; don’t mess about with plugs use through (frame) fixings.
