- Joined
- 18 Oct 2016
- Messages
- 24
- Reaction score
- 1
- Country
Hi All
I have have used bonding plaster over the artex walls in my toilet and plan to skim it with multi finish,
but one of the walls is out of plumb (old house) before I started and is still out of plumb,
but is better than when I started which would not really be noticeable once painted,
but the missus wants the bottom half of the wall tiled and this would reveal the wall not being plumb,
Ie, the edging on the top row wouldn't be flat against the wall mostly at the centre of wall and would be very noticeable, 8mm in places,
So I am looking at plaster boarding over the bonding plaster.
I have applied pva on it, but was then wondering if the dry wall adhesive would stick to this.
I don't want to take it down to brick as the old plaster on that wall is solid, so dry wall seemed the next option.
I would rather use the 9.5mm board because its a small space, but have heard 9mm is a bit flimsy and to use 12.5mm instead, what do you think?
