- Joined
- 19 May 2021
- Messages
- 3
- Reaction score
- 0
- Country
Only wall in my flat that I can use it on. It has a room on the other side but the wall looks rather thick (I've gone along the wall using my knuckle and and the wall has random intervals of shallowness ). Haven't drilled into it but I know it's a dot and dab wall. I've got 100mm shield anchors for the support of a pullup bar. The pull up bar is 7kg/15.4pounds itself but I will be hanging a 45kg/100 pound punching bag hanging off of it. The pullup bar has two groups of 4 screw holes so I've come to ask if I can do it all seeing as I have a slight suspicion that the plasterboard will not support the weight but I will not know until I've done it. I've done as much research as I can muster but only really found that I should have something bridging the gap between the plasterboard and screws. If you want pictures of what I'm dealing with I'll gladly apply.
Dot & Dab wall
Holes/Screws: 100mm Deep, 16mm Wide with Amtech Expansion Bolts
Equipment weighing: 52kg w/ bag attached.
Dot & Dab wall
