the hot water tap in my kitchen has lost all its pressure, the best you can get is a drip! I've had a look underneath at the pipework and there is an isolation valve and what looks like a double check valve above it ( similar to the isolation valve but with a bolt instead of the screwdriver adjustment head).
Any ideas if it could be a double check valve, and if it is can I just get rid of it and replace it with a piece of pipe, as I think it could be this which is causing the lack of water?
Any help would be much appreciated.
Thanks.
Thanks.
