Hi Guys,
I just want to double check if a wall is load bearing.
I have a wall between the Kitchen & Dinning room which spans 3.8m
I've drilled a few exploratory holes in the plasterboard ceiling & wall to find the floor joists for the bedroom upstairs. They are the new engineered lumber beams made of a chipboard & baton like construction about 220mm in height.
The joists are at 600mm centres and run PARALLEL to the wall, they don't sit on top of the wall at all.
The wall is made of thermalite bricks with plasterboard dabbed on & one of the joist sits along the top of this wall, but is the same size as the other joists.
Is this wall load bearing?
If not, is it a co-incidence that one of the joist happens to sit on top of the wall?
