Ah, you know how it is...one unguarded comment, and all of a sudden you've got a Project on
This is the situation: we have a kitchen extension, above half of which is a bedroom, and the remainder of which is covered by a sloping slate roof. In the bedroom, a small doorway under the window leads into the roof void above the kitchen ceiling, and beneath the roof.
Because of the layout of the house - we have a steeply (upward) sloping garden, and there's a 1.5m wall 3 feet from the back of the kitchen, not a lot of light gets in. So stupid here says "Well, I don't think it would be impossible to have that slate roof off, and glaze it with double-glazed units - that'd let lots of light in, and we could take away the kitchen ceiling up to the bit where the bedroom ends.
So, what we're talking here is replacing a slate roof some 3m wide by about the same front-to-back, and at about a 30degree angle, with double glazed units. If the rafters (at 44cm spacing) will support slate, I'm guessing double-glazed units wouldn't be too much of a problem. I would need to find some kind of spacer to fit to each rafter that would hold the glass, and I need to worry about the join between the glass and the slate roof below the bedroom window, and probably a million things I haven't thought of yet.
But the obvious and big questions are:
Is this even feasible?
Are there buildings control implications?
Am I going to have to go for special glass (eg toughened, etc). I'm aware of Schedule L, or whatever it's called, and would be intending to put glass in that was of a suitable U value (this is part of the reason - that bedroom gets DAMN cold in the winter, and I suspect that it's draughts from the roof).
Have I missed some critical thing that's going to cause my house to explode, or flying badgers to come down the chimney?
And where would I go to to get hold of suitable DG units and the necessary spacers/fitments?
