Hi everyone,
Been using this forum at various times in the past and found it very helpful. Only just registered today as I need some advice, so this is my first post. Hope I am posting in the correct section.
We had the asbestos ceiling in our garage professionally removed a short while back and I am about to renew it. There are 2 bedrooms over the garage, so I know that it needs to be replaced with fire protection board.
I called British Gypsum Tech Support today and they were quite helpful.
I was hoping that they did a board that had both fire protection and insulation properties, but unfortunately they do not.
I was told that both 12mm and 15mm Fireline was 30 minute rated, which I suspected, so am looking at fixing a double layer. This will give me 1 hour rating.
The garage is 8M x 2.45M and I know that I have to offset all the joints. The spacing between the joists in 370mm and they run width ways. I was told that the fixing centres should be 230mm centres.
1) Can I get away with using 370mm centres going lengthways? I hope so as the original timbers are on joist hangers.
2) Can I screw through both boards rather than fixing the first board seperately? If so, what size screws would I need?
I'm also looking at hiring a panel lifter for the day to make the job that much easier.
Any advice will be greatly appreciated.
