Hi
hope you can help. i replaced a crome double light switch which i thought should be easy but i now have my doubts.
the switch had 2 red 2 black and 2 earth
i wired the 2 red to the 'comm' positions and the 2 blacks to the '1 way' positions the earths were connected to the earth on the wall plate
all seems to work ok but when switching both light on together the fuse has gone twice in 2 weeks now.
there is a earth connection on the switch should i run a wire from the earth connection on the wall fitting to the switch? this was not connected on the switch i took off?
your advise would be appreciated
