Double oven and Hob
10 Jul 2006
Kent
What size flexible cable from the cooker outlet terminal box should I use for the following :-
Double oven (5.9KW)
Ceramic Hob (6.6KW)
Hi rockerdaveuk
Cable size for Double Oven = 2.5mm square (FLC = 25.65)
Cable size for Ceramic Hob = 4mm square (FLC = 28.7)
Hope this helps
tanglewood
Although you could use 2.5mm for the double oven the cable would be very near it's max rating whenever you used both ovens. I would use 4mm for both as the runs are so short.
