Hi all, I'm hoping someone can help me understand a problem, actually two problems I'm having with my boiler.
The boiler is an older Baxi 105, its had it's share of problems, some of which I've been able to repair, (PCB, diaphragm, fan etc) some I've had to get someone to action the repair for me.
But I've always been able to understand the issue..
But I'm stumped on this occasion.
Problem 1-
No hot water when in water only setting, the diaphragm moves and the micro switch is flicked, bit I get "fault on pump" fault light.
Problem 2-
Following a reset I can get the boiler to work in central heating mode, and this gives me hot water, but the system pressure keeps rising and within an hour the gauge is into the red..
I'm grateful for any thoughts or advice.
Problem 1-
Problem 2-
