I need an extra double socket in my garage, the wire for an outside light is right next to where I want the double socket. If there is a neutral can I take a spur from the lighting wire though an FCU and to a double socket?
No point in a FCU on a lighting circuit.
But apart from that putting a double socket on a garage lighting circuit would be foolish. Think what would happen on a dark evening when you started up your drill, grinder or whatever.
It would indeed be foolish but as I said in my original post the wire is to an outside light and is not part of the garage circuit.
The reason I thought of taking it from the outside light as it is right next to where I want socket. I can run it from the other garage socket but that is on the other side of the room. If that is the only option I will do it but wanted to save a little on trunking and wire if I could.
If that is not possible is it just a case of Running the trunking and 2.5mm around from the other double socket and connect with a FCU? Thanks
