Hi,Good Moaning
I have done a metal stud wall 75mm with 50mm slab insulation and screwed a single layer of 15mm Soundbloc board. (wall is approx. 4m X 3m)
What I need to do now is add another layer of 15mm soundbloc ..
Is it best to just use longer screws to go right through both boards into the metal studs? and I was thinking of maybe using the white foam laminate flooring underlay 5mm in between the boards OR Duralay System 10 Carpet Underlay sandwiched in between to stop any vibrations... what could I use to bond these together?
I know there is green glue and acousticel m20 and similar but they are bit pricey...
