double wall socket replacement - novice lost
13 Mar 2010
Manchester
The old socket cover has 1 earth, 1 neutral & 1 live. Into which three cables feed - each consisting of 1 earth, 1 neutral and 1 live - a total of 3 x 3 wires (9) in all.
The new double socket fascia has an additional Earth "hole" - as well as the "N" & "L" inputs.
I just inserted the 3 neutral wires from each of the three cables into the "N" input, same with the 3 red live wires into the "L" hole, and the 3 green earth wires into the leftmost Earth hole.
The result: A loud bang! Oops.
Which of the Earth holes must I use? Left? Rightmost? Both?
Thanks for any help.
P.S. One of the Earth wires is unsheathed - just the bare copper wire, if that matters/helps.
You can use either or both earth terminals. The earth conductors must be properly sleeved.
Your problem may be because of a shorted conductor (perhaps the unprotected earth)
Times are tough, budgets are tight but should you be doing this yourself without the right level of experience and knowledge? It could cost you more in the long run??
You have probably pinched a wire with one of the faceplate screws, or pinched a wire against the earth terminal on the box (if there is one).
Check all wires for damage and repair as necessary.
All bare earth wires must be sleeved with green/yellow sleeving.
Check all connections are tight before you fit the socket back to the wall.
