I want to put a 2kw Downflow heater into my bathroom. I want to run it from the existing light fitting, the question is do I need a fuse box on the run (if so what rating) + i presume I need to trunk it out?
You can't run a 2kw heater from a 5A/6A lighting circuit. It will need to be run from a ring main or an adequately sized radial. Please note this work is notifiable under part p of the building regs.
I've just put the heater in this morning, seems to be working ok from the existing lighting circuit........when u switch on the bathroom light the heater comes on + is working fine I've used a 'Glen Dimplex GDF20 Wall Mounted Bathroom Fan Heater' (from Argos)
How come it's working Spark123? And I know it comes under Part P, but i'm not gona bother for such a small job. I'll get a sparky in if i have to BUT it seems to be working fine.
Can i leave it as is + if so would i need a fuse box?
in terms of Part P, what would that mean for something like installing a downflow in a bathroom does it offer guidlines or do u have to get it inspected
If you get a properly qualified electrician who is a member of an approved scheme (and if he is, he will proudly say so on his adverts, van and business cards) then he is permitted to test and issue the certificate himself.
If he is a jobbing handyman who also mends fences, reglazes windows and lays carpets, then he is not authorised to do it, and cannot be relied on to do a proper job. Bathrooms are bad places for amateur wiring.
