That won't do anything for problems related to the surface in which the downlighter is mounted. Also, they are fireproof covers - they do not trap or absorb heat. They are intumescent, and their purpose is to restore the fire-resistance of a ceiling by closing off the hole if there is a fire.onesongrg said:HI
You can get a fireproof cover for lights, BUT "YOU NEED TO MAKE SURE THE LIGHT IS DESIGINED FOR THIS USE" it could overheat
¿que?and you need make sure the earthvolt loop impeidence is low so it will trip your mcb or fuse wire.
onesongrg wrote:
earth volt loop impedance
