downlight help please
11 Apr 2006
Essex
I am going to installing 6 downlights in my hall the ceiling rose has 3 cables running from it. only the 3 black wires connect to the rose and the red and earth are taped up
could anybody explain the wiring process to install 6 downlights
many thanks
Nik
Have a look in the FAQ section at the top of the page under: REPLACING A CEILING ROSE WITH A LIGHT THAT HAS ONLY L/N/E CONNECTIONS.
This has step by step instructions and lots of helpful diagrams.
Don't forget part P of the building regulations require you to notify LABC of your intended works.
Rob
Adding a lighting point is in the list of non-notifiable items:
[code:1]
2. Work which -
(a) is not in a kitchen, or a special location,
(b) does not involve work on a special installation, and
(c) consists of -
(i) adding light fittings and switches to an existing circuit; or
(ii) adding socket outlets and fused spurs to an existing ring or radial circuit;
[/code:1]
Providing his hall doesn't fall into the scope of a special location, kitchen or special installation afaict it is not a notifiable task. ;)
Part P. Regulations 4 (2) states that, on completion of work, the building should be no worse in terms of the level of compliance with other applicable Parts of Schedule 1. These may include, but are not limited to, Parts B, E, F and J., For example, one or more perforations of a ceiling lining beneath a floor - made to accommodate recessed lighting or similar fittings - may have an adverse effect on that floors performance in terms of its resistance to fire and sound penetration. Due regard should therefore be paid to the guidance in Approved Document B (Fire Safety) on the performance of fire resisting and compartment floors, and Approved Document E (Resistance to the passage of sound).
All down lighters must be fitted by an installer that is registered by an approved Part P scheme or alternatively, this new electrical work must be notified to and inspected by your local Building Control Officer
