hi, i have cut the downlight hole in a plasterboard ceiling to the correct diameter except that turned out slightly too large (should have made it a bit small and then sanded away at it...) what can i do about it? the hole should be maybe 2-3mm smaller around to stop the downlight falling down slightly. can i just use filler on a mastic gun around the edge (fire risk?!?) or do i need to fill the hole in completely with gyproc and cut it out again?
cheers
cheers
