Downlight loose connection issue
10 Nov 2016
There's a downlight in my bathroom that doesn't seem to have a secure connection. (Excuse the layman terms) The plastic cube at the end of the wire of the transformer has two holes which if you push the pins of the bulb to the metal connectors within the holes, it lights up, but you have to rest the pins within the holes using gravity to maintain illumination. Is it missing a part to hold tight the connection? I'm only aware of two types of pins - I refer to them as thin and fat (with the knob at the end). I'm using thin since the fat ones won't fit (yet the thin ones are too thin for the holes and therefore easily slip out when pushing up the bulb in the ceiling).
You are probably talking about a 12v halogen lamp like this?
The contacts on the sockets of those really suffer due to heat, stress, atc (so do I)!
The solution is to get a replacement socket.
You can get them in loads of places
like TLC and SCREWFIX
Get a new bulb too as bad sockets often damage the pins, which will then damage the new socket! An aluminium reflector type will greatly reduce the heat at the socket, and inside the fitting.
