was looking aruond for answers for the title above.
but was unsure if the link topic was on about hollow soffit or not.
//www.diynot.com/forums/viewtopic.php?t=56460&start=0&highlight=GU10
I know my best option is porbably Gu10 LED bulbs in a IP65 enclosure probably low voltage.
and i should rule out CLF gu10's as they take an age to light up fully ( seeing as is is a porch that will have a pir in the hood aswell it's going to be more and on and off senario than anything else?
but the LED buld seem to be a bit expensive well for decent ish ones
http://www.lightingstyles.co.uk/Acc...mps/LEDs//High_Power_3W_Retrofit_LED_Lamp.htm
so for a two light setup with pir you're talking £100 ish
is it worth it?
could i get by using something else cheaper?
Thanks for any relpies
is it worth it?
