Hi guys, I understand a lot of you don't like downlights so if you are one of these please stop reading now
I would really appreciate your feedback on the positioning of downlight's shown on the following plan:
The light fittings are hooded as there is a loft bedroom above and the bulbs are Megaman 240V 6W LED (50w equivalent) GU10 fitting, 450 lumens 35 degree beam. I actually purchased 10 fittings 6 months ago when they were on offer, but think I probably only need to use 8.
The current pull cord will be replaced with a Hartington Heath LumoS Dimmer Touch Sensor Switch (1 gang 2 way model). I mention this because it has dimmer memory, so in theory if I put too many lights in, I can always dim then down! If there isn't enough light, I'm stuffed!
