Hi
Do you know if the "Electronic Transformer 20W - 60W max" is suitable enough to power " 3 x 12v 50w Downlight with 50mm Halogen Lamps (3 x 20W)". Ok to connect the 3 lamps up with parallel wiring too?
Also, below is the wiring setup where I intend to fit the downlight.. The light that is there now works fine by the way, just wondering what those 3 red wires are there for.
Thank You
Thank You
