In one dark corner of my hall there was an old surface-mounted BC-fitted spotlight, so while redecorating that area I decided to replace it with a new recessed fire-rated LED downlight. I wanted to use a GU10 for this as well for flexibility, rather than one with an integrated LED. I removed the old fitting, secured the end of the cable temporarily in a choc-box in an enclosure, and cut a 70mm diameter hole ready for a new downlight. Then came the problem.....
Because of work apparently done since the light was installed originally there is no access to the ceiling void in that corner (without ripping up fitted cupboards in the room above) so it is essential that I can change the bulb or remove the downlight from below. So I made a 70mm hole in a scrap piece of plasterboard and experimented with various makes/models, so far with no success.
Most ‘can’ types seem to require considerable force to get them back out, to the extent that I’ve broken one ‘test board’ already! I tried a Meridian model where, once the bulb is inserted they seem to push the cables from the GU10 holder back out of the top of the can, but the bulb+GU10 holder do not drop back down when the retaining clip is removed, so you have to take the can out in order to push the bulb out – that’s no good.
I tried the Integral-LED ‘can-less’ EvoFire model – very neat with much lighter springs and very easy to pull out from the front (which you have to do to change the bulb ‘cos of the heat-resistant glass in the bezel), but the problem with that was that it only works with flat-fronted bulbs and I’ve got domed ones for wide-angle lighting.
So, can anyone please recommend a widely-available, modestly-priced GU10 downlight where (a) you can get the bulb in/out easily without needing to remove the fitting and (b) you can get the fitting out of the ceiling if necessary without wrecking it?
Thanks!
Thanks!
