We had 4 downlights fitted in our new bathroom when we had the house rewired but they were not fire hood ones and all the loft insulation was removed in the loft above.
So for 2 of them have we have put a loft cap above them to help with Moisture protection and fire risks.
Loft cap..
http://www.tlc-direct.co.uk/Technical/DataSheets/Fire_Hoods/TLALC724_Info.pdf
However the other two are too close to the joists to have a loft cap fitted so wondering what is the best way forward.
Was thinking if shower downlights would have a better moisture protection on them? but the heat from the lamp will tend to go up into the loft instead of down into room because of the glass lens on them?
There is the the Low Energy Fire rated shower down lights such as the JC94019 which will be a lot cooler?
http://www.jcc-lighting.co.uk/Assets/Fire-rated_downlights.pdf
Has anyone tried the low energy downlights, what is the light quality like?
Any suggestions to the problem of downlights in bathrooms / Moisture protection and loft insulation?
Loft cap..
