You could use a 105vA transformer though. Just ensure the lights aren't tooooo far from it, or you'll have a problem with voltage drop, which will affect the brightness of your lights
Also, selecting the correct size transormer is only a very small part of the work you need to do to meet the 'safety regulations', by which I assume you mean BS7671 17th Ed. Wiring regs and applicable building regs.
