is it safe to use .75mm cable to power downlighters, i know 1mm is the recommended size, but i have plenty of .75 and local stores do not seem to stock 1mm. the downlighters permanent live supply is coming from the main central light into a dimmer switch, then obviously to the first light. the lights are dimmable and they are the non transformer kind. what are the dangers of using .75 instead of 1mm.
thanks
thanks
