- Joined
- 22 Nov 2017
- Messages
- 55
- Reaction score
- 0
- Country
I have had an electrician put in some new lighting to my kitchen, but am worried that I've not thought things through and I've got something that isn't going to deliver what I want.
Installation has a single dimmer switch that controls 6 standard downlighters, but also a 5amp plug socket to connect remotely switched lighting. My intent was to attach a 24v LED power supply to run LED strip along the top of my kitchen units. I wanted them all on the same switch so they could be turned on and off together.
I do want the 6 downlighters to be dimmable, but the 24v power supply will not be expecting to be on a dimmer circuit. Secondly, although the LED can be dimmed, it is done through a RF/zigbee remote.
Is there such a thing as 24 power supplies that will cope on a dimmer circuit? I realise that turning the dimmer down won't dim the LED, I just don't want the LED powersupply to break or malfunction.
Otherwise, I think I'll either need to pick: (a) no dimming of spotlights, (b) dimming of spotlights, but not LED; or (c) replace the current standard spotlights with zigbee versions and have them controlled alongside the LED strip.
Grateful for any advice.
