B
BuildingNovice
I have new single storey kitchen extension with a V shaped pitched ceiling and roof, which has a 150mm void, and want to install some downlights.
Please could someone confirm whether I need a fire-rated downlight (i.e. I am not sure if a ceiling/roof in my scenario, which does not have a living space above it, is covered by the regulations). I could not find the relevant section in the part B regulations booklet.
Irrespective of the above, is it OK to lay insulation around the downlight, or must this be cut back, or should an insulation guard be fitted. I will probably go for the aluminium reflector type to avoid heat being sent to the rear.
I know LED downlights can solve the heat issue, but I have read they do not give sufficient light? Would be interested to hear from anyone who has these installed.
Lastly, are the energy efficiency requirements that 1 in 4 lights need to be EE or 1 light per 25mm2 area, or do both these criteria have to be met? My extension is 50mm2 and so do I just need 2 EE lights, even though I will probably have 20 lights in total.
Is there a good guide on the above on the net somewhere?
Many thanks
Many thanks
