Ok, I know some of you are not fond of downlights, but the OH has spoken. So I picked up a couple from TLC - GUFRD50 with halogen bulbs). http://www.tlc-direct.co.uk/Technical/DataSheets/JCC/GUFRD50.pdf
Its a cloakroom so not too worried about efficiency, but maybe someday I'll replace with LED).
I'm deciding on wiring (they'll come off an Autenco proximity detector) and noticed that they have a L,N and E connecting block, with the Earth on the connecting block not actually connected to the casing, or anything else. The instructions say "This fitting is Class II with provision for Earth termination". So presumably if I wanted an Earth I would connect the terminal block to the casing with a short wire (there's a screw that looks as though its intended for this.)... and then the earth in the cable into the terminal block obviously.
So just wondered whether to link in to an Earth connection or not? What is normal way of doing this? and is there anything in regs that proscribes this.
The Autenco PIR doesn't have any Earth connection so I'd bypass that.
I'm conscious of the tripping problem that someone had in this thread with a unconnected Earth //www.diynot.com/forums/viewtopic.php?t=235012&start=15, although as its a cloakroom I don't anticipate any moisture problems.
Thanks in advance for any advice.
