Hi
We have an onsuite electric haower being serviced by a 6mm from a 32A breaker. However the shower is just about to be changed to a thermostatic shower, with light and fan fed the lighting circuit via a siwtch height isolator in the bedroom.
Three things; The cable is routed up the side bedroom wall adjacent to the bed, to a 45A pull switch. We are about to have the bedroom re-palstered and only have 1 twin power socket in the room and have laminate flooring. Can I use the 6mm to feed bedside sockets if it was downrated at the board to say a 16Amp?
Secondly, are Isolator switches made to last as long as general 10Amp switches by being switched on and off daily?
Thirdly, would re-using the 6mm fall under part p or classed al permissable alterations?
Thanks for any assistance.
