downstairs toilet
30 Nov 2005
Buckinghamshire
hi
could anybody tell me where the shutoff valve for a downstairs toilet and basin would be.The cold tap and toilet cistern don,t run off the mains.There are 2 stopcocks in the cylinder cupboard upstairs so i,m hoping these will work as i don,t want to have too drain the whole system if possible cheers [/b]
As one who knows very little about plumbing, I am in future going to confine my postings to questions which get no response.
Scandy, how on earth can you expect anyone to locate your shutoff valves (if indeed there are any) over a website when you cannot do so yourself with the benefit of eyes and a torch.
You say you've found a "couple of stopcocks" upstairs. Well turn them off and see if the tap dries up. Simple as that.
scandy what you trying to do?
you can bung the cold feed of a cold water storage cistern (tank in loft) and then have minimal drain down
be wary of valves in airing cupboard 1 probably feeds your hot water cylinder so leave that 1 alone (follow the pipes)
both are probably shagged from years of not being used so you could make more aggro than you intended
about the bungs - you may not have seen them - but in the Plumbing and Heating section of your DIY shed you will find a packet with two black, rubber, cone-shaped bungs and a piece of string. They are shaped so that you can push one into the cold feed at the bottom of the cold water tank in your loft (your arm will get cold) and the piece of string is so you can pull them out afterwards.
If there is no tap on the cold feed from the loft tank (and there probably isn't) then the alternative to a bung would be to turn off the cold main and run the bath tap until the cold tank was empty, so the bungs are a lot easier.
Great! hope it goes well.
One thing I will add - if you are using a lamp on a long lead in the loft, hang it up so it can't fall in the water tank. One of my colleagues had a very sad experience which preys on my mind.
funnily enough i was replacing a ball valve up there last week and the thought crossed my mind thanks
