Hi, just wondered if someone could clarify the following for me.
I want to replace the white sockets/switches in the kitchen with something more decorative. At the moment the cooker is connected to a 45A switch although checking the consumer unit it seems that it is a Moeller 32A MCB (PLS6-B32) that is protecting the circuit.
Having looked at the sockets I want to buy, the only listed 45A Cooker control units are those fugly DP main switch & 13A socket combined. There is also a flush mount 50A (with a bigger than normal faceplate) or a flush mount 32A which is of normal size (i.e. the same size as the one I hope to replace).
What I want to know is whether it is okay to replace the current flush mounted 45A faceplate with the 32A DP switch? Since the fuse in the consumer unit is 32A I hope it would be okay. Since I'm not an electrician I'm just a bit confused why the 45A is labelled "Cooker Control Unit" but there is no mention of anything to do with cookers on the 32A!
Sorry for such a basic question, but I'd appreciate a little clarification from those who know!
Cheers!
Cheers!
