I've seen builders putting the dpc at subfloor height which seemed to make sense to me as it was at the right level to achieve a good overlap with the dpm under the finished floor. Now I've noticed that architects seem to show the dpc at finished floor height which seems a lot more akward as, in order to achieve the overlap, the dpc would have to be bent down the inside of the wall. Then what happens at the corners. You would have to cut it in order to bend it down both sides of the corner so then there would be no overlap unless you stick another piece around the corner. Very fiddly. It seems to me that there would be a good chance of dampness at the corners.
The only disadvantage I can see with the first method is that you would need a minimum of 15 inches from the ground level to the finished floor level (6 inches to the dpc plus 9inches for the finished floor) which I don't think would be a problem, two steps up to the door.
Can anyone explain to me the proper way to do this to satisfy building control, especially the problem at the corners?
Thanks.
Thanks.
