Hi there,
I've just had a conservatory built but the floor level has had to be lowered slightly. As a consequence, the DPM on the inner wall is about 2" higher than the floor.
I'm worried that if I get it plastered, instead of any damp being stopped by the DPM, it'll use the plaster to creep upwards - the plaster will bridge the DPM. So I basically need to seal the sides also as the bricks beneath the DPM are above the ground now.
I've mentioned this to the builder and said that we could use something called 'Black Jack' to solve it. Presumably this is some kind of adhesive that I paint onto the bricks that effectively provides a liquid DPM which I can then plaster over?
Does this sound correct?
