Im in the process of installing a ground anchor in a concrete garage floor.
so far ive made the hole in the existing concrete floor and removed the required amount of material to get the required hole depth.
I now need to re line the hole with a patch of dpm where i had to cut out some of the existing one. As you'll see in the photo ive drilled through the dpm in quite a few places.
View media item 98504
Whats the best way for me to sort this out?
Can i just tuck the patch repair up the sides of the hole and under the existing dpm or should i use some sort of joining tape?
