Hello
I am currently converting my garage to a games room. The external wall side, i will be putting in a timber frame then sliding in PIR insulation... However, as for the floor, it is a concrete slab. I will be laying the DPM then insulation....
I am confused to which step to take first.
1) lay the DPM and build the timber frame against the wall first? If I do it this way, I may have to bolt on timber on the floor to make the bottom frame, as such I would be piercing the DPM.
2) build the timber frame against the wall, add in the insulation. Then lay the DPM against the new wall? if so, is this after i put on the plasterboards and skim?
