Hi, i have some truly shocking radiator tails (pics to follow if anyone is interested?!) that i want to replace with chrome pipe - to attach to a towel rail. I have a baxi back boiler with gravity system.
I have two choices in so far as I can tell (correct me if I'm wrong please)
1) Bung the tank in the loft, cut the pipes under the floor, position new pipes (chrome)with a 90deg elbow, and work quickly!
2) Drain the heating down, then the same thing, but with the luxury of a bit more time.
I'm not hugely confident with this, so i thought i'd rule out option one, and drain the system down. Couple of questions about this:
Is this better than a vacuum and quick job, in terms of applying compound sealer to dry pipes v wet etc?
If i drain the system down, can i close off all rads and just drain the pipes, or am i asking for trouble with airlocks or similar?
Will I need new inhibitor if i only drain the pipes and not the who system?
I have auto bleed valves on all the radiators, does this cause any issues anywhere?
Is refilling any easier/harder with a full system drain compared to a partial drain?
I have one two port valve (c-plan system), what do i need to do with this on the draining/refilling please?
Thanks very much
Thanks very much
