We have a one pipe central heating system, and I want to insert a compression equal tee into the supply pipe (and another into the return pipe) to add in some new two-pipe runs.
So I will need to drain down the system.
Trouble is, I cannot find any evidence of a drain valve! This is a bungalow. The combi boiler is in a relatively new part of the property and the one pipe circuit runs along the skirting boards. It ducks under the floorboards in a couple of places, but everywhere I've looked (which is not absolutely every inch of pipe) there is no valve.
So what options do I have? I've looked at self-cutting valves, but can only find 15mm ones.
