Three questions:-
The two pipes each coming out of the top of the boiler - sealed system, not combi - go up to form an inverse u-shaped air trap and each has a drain cock in it. Am I right to use this to bleed any air that might be there?
Also, can I just bleed the pump in the same manner as a rad via its brass screw (above pump)?
Should I have set the three way valve to man when refilling? (Would it be best to start over?)
Cheers!
Cheers!
