I’ve just noticed that the drain cock on my combi central heating has a slight dripping coming out the end where you open or close and the drain opening , l presume it could be the seal .
The only reason l looked was the water pressure is low every few weeks so would this be the cause of the low pressure as all the valves are ok.
The drain cock it self is fairly new and never been touched to drain down so can’t understand why it has started weeping now. It is the Type B and someone said l should have a Type A fitted as the one fitted always leak .
Is there any plumbers tips l can use to stop it weeping without having to get the system drained ..
