Hi everyone.
I have recently moved into a semi detached house built in 1950. I have recently had a blocked sewage drain. We called Dyno Rod out and they cleared the problem however they suspect there is a colapsed pipe somewhere in the system. They are going to use CCTV to establish. They also said that there is a drain underneath the decking area and i have to remove the decking around the cover as there is no hatch access!!!
The only problem is i dont know where the drain cover is! Does anybody know how i can pinpoint the exact location without ripping the whole decking up?
PS whoever laid the decking also nailed everything in place!
Thanks In advance
Thanks In advance
