I drained down my system in order to move the low point drain. However after refilling I bled as much air out as I could and then fired it up....the boiler came on for 20 secs then went off and stayed off....the pipe coming out the boiler was red hot and everthing elses was cold....except the pump which got v. hot after a while. I drained the lot down again and tried refilling to ensure i hadn't done anything stupid. Same problem except this time there doesn't seem to be any water gone in the radiators and if i open the drain nothing comes out.....I have checked the expansion tank and this is full.......Any idea's....it's getting cold!!
