Hello, I am hoping you kind people can help me yet again.
The problem I have now is that whilst I have been redecorating the bathroom I had to remove a radiator in there. The valves on the radiator are very old but I was able to remove the radiator. Anyway the Pegler valve at one end wouldn't completely close so I ended up with a bit of water coming out - right into the kitchen below.
I have put the radiator back on but the valve is still lightly weeping.
Anyway I intend to replace the radiator with a chrome towel rail, which will need to adjust pipe work and then I can also replace the valves.
To do this I can see that I need to drain down the system.
Am I right in thinking this is the correct procedure?
1) Turn off the boiler
2) Make sure that all the radiators are open
3) Drain the water out of the system using the drain valve
4) Open the bleed valves on the radiators? Starting from upstairs (I'm not sure about this?)
5) Have some towels ready and do the pipework on the radiator in the bathroom and install the new radiator
6) Add inhibitor to the system, is Sentinel the best to use? Do I just add this to the new radiator before I put it on?
7) Close all the bleed valves starting downstairs to upstairs?
8) Close the drain valve and turn the boiler back on and use the key on the Worcester Bosch boiler to refill the system (get the pressure up to 1 bar?).
9) Check that the new radiator is working and check for leaks.
10) One at a time open bleed valves on the other radiators to remove any trapped air in the system, then close the bleed valves.
I guess I'll need to re-pressurise the system again at this point.
Does all that sound ok? Is there anything that can go wrong and that I should worry about?
Incidentally I had a new boiler installed 2 months ago (should have got them to do this all at the same time, but my wife hadn't made her mind up at that point. But when I emptied the bathroom radiator, lots of black sludge came out, should this have been cleaned from the system before the new combi was installed?
Thanks again and sorry to bother you all.
Richard
(By the way I have not tackled the soil pipe yet, I have got all the bits and am ready to go..just waiting for a dry spell.)
Richard
