Hi
I have a combi boiler sealed CH system, supplying 10 radiators. I previously fitted a trv to a lounge radiator using a pipe freeze kit. I now want to fit trvs to 8 other radiators, leaving the bathroom one as it is [permanently on for drying towels].
I have located the filling loop and drain tap, and am planning to drain the system so as to fit the trvs this weekend. I have obtained a kit for adding in corrosion inhibitor via radiator bleed valve when I refill the system.
Is there anything I should watch out for?
Should I close the valves on the CH flow and return pipes under the boiler?
What about turning off the boiler completely [including DHW] while working or can I just turn off the heating?
I am getting a bit worried that some websites say do not attempt to drain sealed system with out professional help
Any advice gratefully received!
