Solid fuel stove has 1 feed and 1 return. I presume that there should be a drainage valve on the return before it enters the stove, correct? I'm assuming that given the circuit has to be able to thermosyphon, that will be the lowest point?
It's not fitted yet but it's a duel aspect stove so the pipework will be clearly visible for a short run at least - and I can't think of anyway that the drain also not be visible.
Can someone confirm I'm not missing something?
