Drainage entering a building slab/ timber frame stud wall?
11 Oct 2011
Dorset
2 Quick questions, in a new build (not domestic) can I bring drainage into a building, up through a reinforced slab and terminate it inside a timber frame stud partition? (its not a load bearing wall) or does it have to be in the room?
I want to mount a wall basin and hide the waste pipes in partition. (rather than have a pedestal)
oh and anyone know where I can check up on this in the regs?
The other question is considering its a raft slab, rather than having strip foundations and a lintel over drainage, can I have the drainage shallower under the slab? i.e its all a huge lintel so can I have the drainage quite shallow with correct gradients?
Thanks all :)
