Hi all - I have water leaking from my kitchen ceiling. The kitchen is located directly below the bathroom, so I checked behind the bath panel for leaks - it was bone dry there. I then looked at the shower enclosure, and it looked ok. However, after running the shower for a bit, the water started leaking through the ceiling again. This makes me think that the waste pipe from the shower is leaking.
I also noticed that the 'plug-hole' located in the shower enclosure has no sealant around it, and the whole assembly will move if it is pushed. It is not exactly loose, but it will move. Is it possible that the waste pipes under the floorboards are ok, and the water is finding its way through to the kithcen ceiling from around the plug hole assembly? (I hope that makes sense!)
I really hope this is a simple fix, as I have no access to the shower waste pipe without removing the tiles and shower base.
Any help would be very much appreciated!
Cheers - Den.
Cheers - Den.
