Does anyone know if there is a way of draining a dishwasher /kitchen sink and washing machine waste from a building to ground ie a soakaway which is acceptable to Building Control ?
Couple of info bits below should get you thinking in the right direction. Although I'm in scotland, I think the second BSI code of practice qill be UK wide..
Anyway, you'll be able to distinguish between the system you will need. Probably a ' sub surface ' grey water system, that doesn't involve storing the water..... ?
Rainwater harvesting and other water reuse systems
A guide to safe installation and use
