I'm about to lay some ground drainage which will run into a solid pipe under the driveway and off to the drain. My question is ...
Is 100mm ducting pipe OK to use or should I be using something more solid. The pipe will be buried approximately 2-3ft down and surrounded by 10mm pea gravel (or should I use concrete?). The drive will then be covered at a later date with imprinted concrete.
It may also be worth adding that there will be no traffic passing over the pipe area.
I chose the ducting simply because I figured it would be easier to join the 100mm land drain pipe. Ideally the pipe would be smaller but I wouldn't know how to connect the two pipes together!
Many thanks!
Many thanks!
